So I have Cooper Boggs (husband of OCR President Nicole) cleaning my undercarriage. Pounds of crap is coming off (it's a clean driver with 107K on it) and I start to fix little things.
Got the bellows wire back onto the wheel. Removed the frame and did not touch the wire or the wheel. Big good thing. Bellows frame goes on and off with 10mm bolts, rather than touching the wheel bolt, which goes into the engine oil area. By simply taking off the bellows and frame and still attached to the wire, getting it on the wheel, then stretching the bellows back onto the 2 bellows frame bolts in the engine case, I got it back on with almost no effort!
Put a new cup in the shift plate coupling. The old one was basically dissolved. The new one means no more looking for gears. All the other fittings were done, but this one was easy by removing the allen nut and popping the new one onto the ball then the coupler back onto the shift rod. Coupling came RIGHT off the shift rod! THIS WAS BIG GOOD! OH MAN I CANNOT WAIT TO SEE HOW GOOD SHE SHIFTS NOW!!!!!
Helicoiled the speedo assembly pin bolt back into the speedo and lubed the new o ring again. PO stripped the bolt and did a really crappy heli job years ago, and it was fix it or have the entire speedo assembly fall out on the road along with my 90W lube. This was good, but it should never have been stripped out in the first place. After taking it out once, I put it back but felt the heli flexing from a bad install. We got this one right almost the first try. Used only one coil, but put it in backwards and tapped off the end into the speedo channel, dremeling the remaining coil till it was flush with the back end of the tranny bolt hole.
Had to buy a coil kit and 3 bottles of Lucas 90W just to dump the new 90W to get the work done. $50 bucks, but worth it to not lose the parts on the road.
Kudos to Cooper on all of this, as he took breaks in the cleaning rituals to stop and help me. He actually installed the helicoil. We make a good team!
And Cooper also fixed my gas tank that had a return nipple leak. Took the tank out and back in fixed in half a day.
I get Orangina back on Monday night. But when he is done, I have a ton of sanding and black respray on the trailing arms to do.
I will post finishing pics. I have to remember how to reduce the 3MB size to something that fits here. Progress pics are just too big.
John
avidfanjpl
