I'm replacing the motor mounts this week in my 74. I did it once in a Spitfire, and it was a piece of cake, I'm guessing this will be a bit harder, but looks OK. From what I understand, I need to put a jack under the trans to take the weight off the engine bar,I pull the 2 small bolts in the engine bar where the mounts are, and that frees up the mounts themselves, and then I need to loosen the large bolts on the ends of the engine bar to allow me to get the mounts out. Then screw the new ones in, tighten everything back up, and I should be good, sound about right?
Anything I'm missing? Anybody have any tips?
Thanks!
Mike
