How is the nut held in place for the bolt that holds the fog light bracket to the body?
I think someone has changed mine in the past as one uses a bolt and the other side a allen screw. Problem is if they get loose the nut in the back is not secured or tack welded in place.
Can a person take out the pop up headlights to get acces to the nut in the back to spot weld them in place?
