914ltd
Jul 13 2010, 10:58 AM
914/6 original oil tank with filler neck and oil filter console $750.
914/6 original throttle linkage, cable and cable bracket with a fabricated bracket to bolt the bellcrank shaft to your later 914 transaxle (Rich Johnson has a nicer version of this bracket available) $200.
914/6 transaxle intermediate plate with threaded hole for throttle bellcrank. Can be changed without disturbing the pinion depth spec (save your old shim gasket measurements) $45.
911 110mm axles, spacer, stub axles, 5 bolt flanges and 110mm transmission output flanges. A complete, no modification conversion to heavy duty axles and 5 bolt. Will work with 914 or coarse spline 915 transaxle. $425. SALE PENDING
914/6 original engine sheetmetal with a non original, fabricated RR piece. scroll down for a picture of this piece. $450.
914 Mocal dual 19 row oil cooler system. Mocal thermostat, sheetmetal and -16, (I think) Aeroquip hose. The hose ends are clamps not true Aeroquip style connections. This did not come from a car with an engine failure, no metal contamination. Racer price new is $179. each on the coolers alone. $200.
914/4 rear calipers with spacers and rotor spacers for vented rear brakes. Rotors included but need turned, I would recommend rebuilding the calipers, I can ship these directly to Eric if you like. $150. SALE PENDING
Return anything not to your expectations, no restocking fee. Shipping at my cost plus $3.00 Brad Mayeur 309-694-1797
914ltd
Jul 14 2010, 08:28 PM
QUOTE(914ltd @ Jul 13 2010, 09:09 AM)
Calipers
Picture of the reproduction piece included with the 914/6 engine sheetmetal set.. Brad
rick 918-S
Jul 15 2010, 04:27 PM
I think jmill (John) is looking for some stuff. I'm sending him a PM now.
jmill
Jul 15 2010, 06:25 PM
Thanks for the heads up Rick.
I wish I could take it all. I don't have the cash. I will take the intermediate plate. I'm undecided on the linkage. I'll have to let it marinate a bit.
bobhasissues
Jul 15 2010, 07:19 PM
Brad,
Dibs on the spare wheel/tire in the above photo if it is a FOUR Lug and is for sale.
Please quote me a price if you are willing to part with it.
Thanks,
Bob Mitchell
Gigamight
Jul 15 2010, 08:40 PM
QUOTE(bobhasissues @ Jul 15 2010, 09:19 PM)
Brad,
Thanks,
Bob Mitchell
If that's a 4 lug, it's the oddest pattern I have seen
914ltd
Jul 15 2010, 09:16 PM
QUOTE(bobhasissues @ Jul 15 2010, 05:19 PM)
Brad,
Thanks,
Bob Mitchell
It is a 5 lug, I have nice 4 lug rims but have never changed the space saver???? Brad
dwy914
Jul 16 2010, 09:02 AM
I'll take the axle set if the cv's are in good condition and the rear brake stuff as well.
Dan
Dwy914@gmail.com
805-202-9369
racerbvd
Jul 16 2010, 03:32 PM
Gee Brad, hope these aren't off a certain Red 914-6[color=#FF0000]
Joking....
