QUOTE(raw1298 @ Jul 19 2010, 12:27 PM)
This is supposed to bolt up? It was welded when I got the parts. There is no hole (filled in by welding?) to bolt into. Should I just weld back or is there a better way? I also am not sure how to line this up. Any threads or pictures would help. I am refering to the linkage.
Hmmm, that shift rod should be one piece...
If you don't get the angle right in securing the two pieces of the bar together, it will not be easy to align the linkage.
I'd recommend getting another side shifter bar to compare to (OR REPLACE).
