I have a Subaru motor and 5 speed tranny with a Bremar tranny kit just about ready to install in my '75. What shifters/linkages will work?
Will most any mid-engine shifter and shift cable setup work?
Toyota MR2? Boxster? How about adapting 911 linkages and shifters?
What about shifters and linkages from modern Hondas, Toyotas and the like? Since they are cabled to the trannys too, will they work? Will most 5 speed cable connected linkages work?
Does a shifter and linkage have to be mid-engine? Cable linkages? 5 speed linkages?
Does the shift pattern need to match the Subaru's? Are there good aftermarket setups?
I guess you can tell I don't know much about what is involved here.
Thanks for any help pointing me in the right direction.
