I would like to know the proper procedure for setting the timming on a 74 2.0 using an inductive timing light? I have all the marks on my fan but also would like to know exactly what they are (picture attached are from vw ratwell showing a notch on one side and then a "0" and another line mark on the other side), I recently powder coted my fan and painted only the "long line" mark but not the "0" or the notch on the other side....
other issue is I have a dual port throttle body on a 74 2.0... will this cause me problems?
also confused as to should I even use the dual port at all on a 74 dizzy and vac cannister... what should I expect..
but am unclear on which hoses or both to disconnect and then plug at the throttle body from vacuum cannister.. ..
I have read that I need to run the car at 3500 rpm while timing
here is what I have to work with
74 2.0 w/
crane fireball xr700 electronic igniton
0 231 174 011 (dizzy) stock 74
1 237 122 603 (vac) stock 74
dual port throttle body stock 73
Excuse me for the multiple questions but when I learn something I like to know why and not just follow direction without comprehension of why...
fan housing marks pics.. what side are they as installed in completed engine..
I believe I saw the "notch" in the first picture when I was adjusting my valves so that is TDC? and then the onther "0" and "long line" are on the other side towards the rear of motor?
I believe the "long line" mark is 27 deg. BTDC and is what I will be using but what is the "0" then?
