Clamp the cold start injector fuel line and try it. I had a problem with mine being open, and I replaced it. For a while, I clamped it, and it started on the first try.
Is it running rich when it does start and run? You can tell easily, because now that mine runs right, there is no unburned fuel smell at all.
Sounds like, but I can't be positive, too much fuel at startup, as mine did the same damn thing until I solved all the issues.
Also, check your throttle position sensor. There are links that show what ohms it has to be at to set it on here and on Pelican and on the Anders DJET site.
That was also a big thing for me.
I run points, and that was a little issue for me.
Sounds like we both have Signal Orange 2.0L's from 1973. Mine was made in 9/72.
Engine GA000386
Do you know yours?
Best of luck!
John
avidfanjpl
QUOTE(rwilner @ Jul 15 2010, 02:55 PM)
My 73 2.0L is hard to start when cold. It cranks for about 5 or 10s, and will slowly catch.
I made this video so you all can see exactly what happens.
When the car is warm, it will start up in 1 second (1 or 2 engine turns), as expected. IOW, if I run into the store to get some milk, when i come out, the car starts right up.
i've done the following:
- Cap, rotor, plugs, wires, oil change, valve adjust
- Set timing: it's dead nuts 27 deg BTDC @ 3500 rpm
- Changed the fuel filter (I did that right before I made the video)
- Replaced all the vacuum lines in the engine compartment
also relevant:
- I have no points in the car -- it's a crane optical unit (XR3000). fuel injection is stock otherwise
- Fuel pressure is about 31lbs when operating
- idle is very steady between 900 and 1k rpm during operation
- PO put in a new bosch fuel pump less than 5k miles ago
Where would you guys go to start troubleshooting next? I'm thinking cold start valve?
Thanks!!
Rich
