RiqueMar
Jul 15 2010, 08:30 PM
My Dad is exploring the possibility of a converting a 3.2 Motronic engine to Carbs. However, the problem is that the distributer is different. The only option seems to be to recurve the distributer. However, we have heard rumors that if you can find a distributer off a 2.7, you're set?
Any truth in this? Personal experiences?
Mark Henry
Jul 15 2010, 08:53 PM
I know you can't do it on a 3.0 because it spins backwards.
About the only other option is a megajolt jr. or MS system or an after market crankfire system.
(If it works I have a 2.7 bosch dizzy.)
Brian_Boss
Jul 15 2010, 09:13 PM
QUOTE(RiqueMar @ Jul 15 2010, 09:30 PM)
There is not really anything to recurve in a stock motronic dizzy. It does not control spark timing. There are no points. All it does is send the spark to the right cylinder. There is an advance mechanism but it only serves to keep the rotor pointing at the terminal in the cap as the spark is advanced by the ECU. The timing is completely controlled by the ECU based on a programmed advance curve and input from the flywheel position sensor.
RiqueMar
Jul 15 2010, 09:46 PM
QUOTE(Mark Henry @ Jul 15 2010, 07:53 PM)
Exactly, the direction is different, which I believe matches that of a 2.7. Hmm, if I find that it is simple as that, I'll def keep that in mind
QUOTE(Brian_Boss @ Jul 15 2010, 08:13 PM)
Yes, but when switching to a carbed engine, wouldnt you need a conventional distributor?
GeorgeRud
Jul 15 2010, 11:06 PM
It sounds like you'd be taking a step backwards to go from Motronic to carbs. Unless you're doing some other modifications to the cams, pistons, etc., the carbed engine will not run as well as the Motronic engine.
championgt1
Jul 15 2010, 11:18 PM
Why would you want to change to carbs?
eitnurg
Jul 15 2010, 11:32 PM
BTDT. The 2.7 distributor has way too much advance (about 35deg all-in) and should be re-curved to max 25-28deg (see
http://www.911chips.com/ignition.htm for the 3.2 advance curve). You can run it unmodified, with the timing backed off but this means it runs way too retarded at idle: you get a terrible off-idle bog on acceleration (which the carbs just add to) until the revs rise and the advance mechanism catches up. Alternatively a locked distributor and something like a MSD timing computer works well - until it breaks.
The "direction of spin" issue is lost in the mists of time. These days I have trouble remembering what I had for lunch yesterday.
Otherwise concur with what's already been said: if the Motronic is set up & running, leave it be.
RiqueMar
Jul 15 2010, 11:33 PM
QUOTE(championgt1 @ Jul 15 2010, 10:18 PM)
Yes, it is, in a way a 'step-backward', but its also rather nostalgic, which is what he wants.
Jul 15 2010, 11:40 PM
QUOTE(RiqueMar @ Jul 15 2010, 10:33 PM)
Ah yes, the good old days of clogged idle jets, flooded bowls, non-existing cold start, out of sync running and crappy gas mileage ...
Those were the days!
Andy
RiqueMar
Jul 16 2010, 12:03 AM
QUOTE(SirAndy @ Jul 15 2010, 10:40 PM)
Andy
But they sound sooooooooo cool!
siverson
Jul 16 2010, 12:49 AM
Not when they have "clogged idle jets, flooded bowls, non-existing cold start, out of sync running and crappy gas mileage".
I agree, stick with the Motronic.
-Steve
IronHillRestorations
Jul 16 2010, 07:51 AM
The only way to go would be with new PMO carbs. They are made differently and don't have the same problems the Webers have with idle jets getting stopped up.
I'm with the other guys though, your Dad needs to drive a 914 with a 3.2 Motronic engine. Reach in turn the key, no snappity-pop-pop, no "look how fast I can change fouled plugs", modern FI.
BigD9146gt
Jul 16 2010, 09:13 AM
Not sure what your dad has on the motor already, but that mass-air flow conversion and chip help with some power, and with the cone filter you can hear more of the air going in... Dansk sport exhaust and that noise will provide more than enough nostalgia.
If you must go carb'd, PMO. If you want supa nostalgia, PMO EFI stacks and stand alone setup. That will give you tingle in the most desirable of places.... just not the wallet area. That will feel more like pins and needles dead leg feeling.
sean_v8_914
Jul 16 2010, 10:14 AM
I would use EFI on every engine if I could afford it
Cupomeat
Jul 16 2010, 12:29 PM
Stick with the FI, the car is nostalgic enough.
Eddie914
Jul 16 2010, 12:58 PM
I have a 3.2 with Webers. I wanted Motronic but the induction was sold from the wrecked 911 before I showed up to buy the 3.2.
As long as the fuel is kept free of water it runs great. A few pumps of the accelerator on cool mornings and it fires right up. It sounds and looks nostalgic too.
I'm running the same distributor (and carbs) that came off the 2.7 that KABLAMMOED in my conversion 914-6. The PO did the conversion so I am not absolutely sure what distributor it's running. It still has points, Permatune CDI, Black Bosch coil and mechanical rev limiter (6700 rpm ditributor rotor).
I will look to see what numbers are on the distributor. I am gone for the weekend so I will look next week.
Cheers,
Eddie
MoveQik
Jul 16 2010, 01:19 PM
QUOTE(Cupomeat @ Jul 16 2010, 11:29 AM)
I agree. Been from sea level up to 11k feet and everywhere in between. Car starts and runs perfect with a simple turn of the key.
RiqueMar
Jul 16 2010, 02:37 PM
QUOTE(Eddie914 @ Jul 16 2010, 11:58 AM)
Cheers,
Eddie
Eddie,
Thanks for the input, please let me know all that information, it is greatly appreciated. Clearly, there's not alot of info on the subject.
naro914
Jul 16 2010, 03:47 PM
We went from a carbed 2.7 to a motronic 3.2 in Huey and I would rather walk everywhere than go back. It is soooo nice to just jump in, turn the key, and go. No coughing, no backfiring, no clogged jets....
Granted, Papa Smurf has PMO carbs, but it's highly modified and there is no FI to make it work right.
If you build an engine for carbs (correct cam profile, compression, etc) I think it comes out great. But if you just retrofit FI with Carbs, it may not work as nice.
Mark Henry
Jul 16 2010, 08:01 PM
QUOTE(naro914 @ Jul 16 2010, 05:47 PM)
And that is your answer,
I don't agree with all the detractors of carbs (and that coming from a SDS FI guy) but sticking a set of carbs on a FI engine will never give you the result you want.
RiqueMar
Jul 17 2010, 03:05 AM
Guys, you'll get no argument from me as to which performs better, I'm in agreement, the Motronic rocks
. I just want to see if it can/has been done.
seebobgo
Jul 17 2010, 01:49 PM
I have 46 PMO's on my 3.2 and she sounds great wide open! You will also need a lot of spark to burn all that fuel you will be pumping. I have a MSD 6al.
But.... the car had 40mm webers that were a bit worn out and to small for a 3.2. If it had FI I would have left it alone.
Get ready to spend big bucks and a lot or sorting out time.
campbellcj
Jul 19 2010, 10:31 PM
I like modern EFI and would go that route on a daily-driver or no-holds-barred racecar; however, carbs just have that vintage appeal and "bling" that is tough to beat when they are working well.
Mark Henry
Jul 20 2010, 12:31 PM
QUOTE(campbellcj @ Jul 20 2010, 12:31 AM)
It that bling...or is it more like Sha-Wing
naro914
Jul 20 2010, 12:46 PM
so, here's a question....
can you run Motronic with PMO throttle bodies?
if not, how about Megasquirt - that would give the look and hopefully EFI reliability....
Mark Henry
Jul 20 2010, 12:54 PM
You could run webers with aftermarket FI easy. Many peeps use carbs as TB's.
Series9
Aug 8 2011, 05:42 AM
QUOTE(sean_v8_914 @ Jul 16 2010, 12:14 PM)
and no distributors too.
Sorry this is a late post. It was in a search I ran and I didn't realize how old the thread was.
JmuRiz
Aug 8 2011, 10:44 AM
I would think an electronic crank-fire ignition would be the way to go if changing from DME to carbs.
However if you want a real nostalgic experience, I'll trade my 2.7 and carbs for the 3.2, hahaha. Nostalgic as in carbs and not nearly as much power...
Keep us posted on what he decides and the progress.
I'm sure the bird-board has lots of info on 3.2 engines with carbs.
Aug 8 2011, 10:54 AM
QUOTE(RiqueMar @ Jul 17 2010, 02:05 AM)
Damn you!
patssle
Aug 8 2011, 01:54 PM
I just did the 3.0L conversion myself (from CIS). It looks 10 times nicer and sounds about 100 times better. And less junk in the trunk!
