QUOTE(bandjoey @ Jul 15 2010, 09:10 PM)
Looking for suggestions before pulling out the instruments. Turn signals, Flashers, Handbrake, Oil, Alternator, Gas, Highbeams all work OK. The backlighting is out.
What's the common reason for this one? Thanks.
That would be the black/blue wire from the headlight switch. Fuse 7 provides the power for the dimmer potentiometer (black/blue) then the black/blue wire goes to all the lamps. Pull the switch out and test for voltage on terminal 58b (from fuse) and 58a (output to dash lamps).
