I was taking out engine tin and one screw just won't budge. It's the one over the cylinder#3 and under the intake pipe. It has 3 spade connectors for grounding harness under it. Is it safe to drill it out? Thanks, Mike.
kenshapiro2002
Jul 16 2010, 08:34 AM
Try a penetrating fluid first...then hit it with a heat gun. Bet it'll budge then.
QUOTE(mikea100 @ Jul 16 2010, 10:33 AM)
I was taken out engine tin and one screw just won't budge. It's the one over the cylinder#3 and under the intake pipe. It has 3 spade connectors for grounding harness under it. Is it safe to drill it out? Thanks, Mike.
Krieger
Jul 16 2010, 08:42 AM
and some vice grips.
TheCabinetmaker
Jul 16 2010, 09:34 AM
Impact screwdriver. If ya don't have one, you need one anyway. Good excuse to buy a new tool.
McMark
Jul 16 2010, 10:09 AM
impact screwdriver.
SUNAB914
Jul 16 2010, 01:35 PM
I agree with tool above.
Cap'n Krusty
Jul 16 2010, 01:54 PM
When you put it back together, install the ground lug plate under the appropriate case through bolt, where it belongs.
The Cap'n
watsonrx13
Jul 17 2010, 05:15 AM
QUOTE(Cap'n Krusty @ Jul 16 2010, 02:54 PM)
No automotive tool box is not complete without a rusty carpenter's claw hammer !!
I know , I know , it's a hammer just the same .
Jack / Jaxdream
mikea100
Jul 17 2010, 09:13 PM
Thank you guys. The screw is out. It took 2 people turning at the same time: 1 w/ vise grips and 2 w/ big screwdriver. I'm gonna anti-seize the crap out of this car when I put it back together.
