This car (74 1.8 w/ sgl carb) had been off the road for the last 15 yrs. It drives pretty well now after 5 yrs of work but when backing off the gas the throttle stays at that speed. I have to blip the gas pedal to get it to back off. I'm guessing the throttle cable could use some new grease??? Stepping on the gas is not a very fluid operation. My previous 914's throttle worked with little effort.
What's the best way to do this? Loosen cable at the carb and at the gas pedal linkage and pull to the front of the car or rear? Didn't want to completely remove it from the car as I figured it would be a PITA to put back in.
There is a new throttle return spring and the carb linkage works ok unless it is getting hung up somehow and not completely closing???
Anything else I should chk? Thanks in advance for the guidance.
Ed
