Yeah Mark - I agree with the above - the heater flapper boxes with hoses to the heat tubes from the rocker/longs space to the front if left disconnected can do 2 things -
1. when you run the ventilation fan up in front of the dash, it will still pull in some hot air from the engine bay through the open tubes, and
2. without the flappers connected to the HE's, they cannot blow off hot air pumped through the HE's to cool it down. They direct heat to the cabin in cold weather, but likewise vent off hot air from the exhaust system in warm/hot weather. So the engine & bay may be significantly hotter than OE spec with it all hooked up!
You should keep the heater/HE system hooked up on a stock engine set-up of any flavor (including all tins) - even if you don't use the heater - because the overall operating cooling profile was based on the entire system of airflow & oil cooling with everything hooked up & working properly. Even simple holes in your old HE's can vent heat at the wrong points & add to the engine heat, rather than cooling it.
Dansk makes a nice pair of replacement heater flapper boxes for $70-100 each side L&R (they were one of the OEM suppliers), plus the hoses & cables are still available - if you want new. Check at AA, PP/Automotion, Pelican, etc. Otherwise there are used ones advertised on here, 914club, TheSamba & eBay, but get new hoses at least, cuz they get brittle.
Rows 4 & 5 fo boxes & hoses, cables, etc. throughout - IIRC yours is 75?
http://www.automotion.com/catalogsearch/re...p;x=28&y=11http://www.automotion.com/product.asp?pf%5...;dept%5Fid=4496A little more to do on your 914 I guess!
