After a short drive to try and zero in the fuel parameters on the SDSEFI I noticed the oil pressure dropping from fifty to twenty psi. I freaked out and went home which was only blocks away. When I got home I pulled into the garage and watch hot oil puddle on the floor. Scared to death I put her on four jacks and crawled under to see what was up. I had cleaned the engine prior to the drive so I could tell whereabouts it was coming from. It was above the oil filter, but that is all I know. I am assuming it is the oil cooler. Though I don't know what in that area could also spew oil.
I need help figuring this out. Can the oil cooler be removed and re-gasketed in the car? Is there something else that could be leaking right there? I can refill some oil and start it to see more clearly but I not sure that would be a good idea or not.
HELP
Love always, Joe DiTommaso
