Just wanted to say hi and show some pic's of my new addition, 71 1.7 914. This will be my first time owning a 914 or any type of air cooled engine so this will be a learning curve. The car was original from AZ and can you believe the owner actually paid for undercoating and has been located in Up-state NY for the last 25+ years. Other than some rust buy the passenger’s side rear lift point she’s ok. Paint looks good from 15 feet and the interior needs some TLC. I've already learned about the oil leak issues. plus some.
Now first and foremost I need to get the car into "Reverse", I'm changing all the shift linkage bushings or whatever they are called in hopes that fixes it. This car shifter swims into gear..
Coming off the trailer, she was in Up-state NY and now on Long Island NY. Thats Jon in the foreground the truck driver thats saved me from the 16+ hour drive to pick her up.
Yes those hub caps are going ASAP
Look what I found, just missing some parts but I'll get them someday
Only overnight, this is a lot of oil. Going to see what this is all about...
Figured out the major oil leak, it’s the push rod tube o-rings must have gone bad from the car sitting. The heat exchangers are covered with oil.
Also found the fuel pump, looks like I'll be ording some new rubber mounts
Some good news, look at this underbody
Well for a car that’s been by Niagara Falls NY since the early 80's and not going into reverse this tweener has some potential for a period correct/weekend driver.
Thanks for looking,
Kalva
