QUOTE(Eric_Shea @ Apr 14 2004, 12:32 PM)
Just got my RS MFI throttle bodies and stacks back from Harry Bieker. $1350.00
Pump goes off to Gus Phister next week. $1600.00
Sounds very cool Eric! You won't beleive the throttle response that engine will have. Nothing pulls like MFI! Some of the best factory race cars used MFI (including most all race turbo'd engines up through the mid to late 80's) for a reason.
I had Gus do a pump almost ten years ago and it was $750 then, but that was a stock rebuild on a 2.2E pump.
Last summer I got lucky and found a core 2.2E engine with about 2500 miles on a set of new intakes.
If you have a 914-6 relay board with the RPM transducer, it should work to activate the idle pull down solenoid on the pump. The 914-6 transducer was a factory recommended replacement for later MFI 911's with balky idle pull down. The way it works is when the engine drops below a specific RPM it activates the solenoid on the pump to pull back to the idle position.
You can use the stock air cleaner, but you have to modify the snorkle, the airbox, and the engine lid. On a six conversion, I guess you could mount the engine a little lower, and that would help too. I gave up on Watershields, but I'd probably do like Michael and massage them to work the next time.
The Ed Villela strut kit for the rear lid would be a good idea too. The factory torsion springs are very close quarters installing the engine.
The other biggies I remember are the fuel pump (what I call the supply pump, not the MFI pump), and the fuel filter console. The system requires the correct Bosch supply pump, that looks like a stock 914-6 and 914 pump, but has a different output. The fuel filter console uses a filter the size of an oil filter (and runs about $30) and also has the (WWI vintage) fuel enrichment solenoid, where you shoot raw fuel down the barrel of the injection stack for cold starting. I just hooked up a momentary contact switch on the dash and hoped it wouldn't burst into flames. The factory cold start system has a thermo-time switch that supposedly did the same thing.
Don't know if any of this helps. I did make out a wiring diagram for the MFI/ignition curcuitry. I've done two plug and play wiring harnesses for 914-6's with MFI. I'd probably trade one for some white panties with a 914 on them
PK
