Jerry75914
Jul 27 2010, 11:29 PM
Hi all,
I'm trying to put together my rear suspension. I have Bilstein HDs and Weltmeister 140lb springs. I removed the hat and related parts from my old assembly, and now I find that the threaded bushing is just too tight for the Bilstein.
Anyone run into this? Do I need a different threaded bushing? Can I just run a slightly larger tap through it? It threaded about a third of the way before it was so tight I started stripping the hex head insert in the top of the strut...a totally differnt problem.
Appreciate any advice!
Jerry75914
Jul 28 2010, 09:53 AM
tradisrad
Jul 28 2010, 11:33 AM
Jerry, Are you talking about coil-overs not fitting? Or the nut that holds the strut in the car? I am not sure what the threaded bushing is.
-Rob
Jerry75914
Jul 28 2010, 11:55 AM
QUOTE(tradisrad @ Jul 28 2010, 10:33 AM)
-Rob
Hi Rob!
It's the conical "nut" that holds the top hat looking gizmo on the coil. The nut that goes on last from the trunk is fine (came with the kit).
tradisrad
Jul 28 2010, 12:13 PM
MY best guess is that it is the wrong thread pitch.
jcd914
Jul 28 2010, 01:27 PM
QUOTE(tradisrad @ Jul 28 2010, 11:13 AM)
IIRC Bilstein's use a finer thread pitch than all the other rear shocks.
Jim
tradisrad
Jul 28 2010, 01:58 PM
Jerry I may have some other conical nuts at home, but I bet they are for the Boge or some other strut. I'll look for them and let you know what I find.
Jerry75914
Jul 28 2010, 03:27 PM
thanks Rob! I'm going to try and tap it to be jsut slightly larger...I called Porsche Parts Heaven and asked if there was a differnt one for different shocks and he said they should all be interchangeable....oh well!
Mike Bellis
Jul 28 2010, 04:13 PM
One of my Bilstein's was like that. It was bent. The conical nut would screw on fine on my other set.
Jerry75914
Jul 28 2010, 11:35 PM
Congrats to everyone that thought it might be a thread pitch issue...it was
looking at it tonight, without the red mist of frustration, the Konis were definitely a finer pitch. I re-tapped the bushing with a 12mm, 1.5 pitch die and it screwed on like butta...
thanks for the advice all!
tradisrad
Jul 29 2010, 08:58 AM
Good to hear. I was going to see if I had any for you, but now I don't need to.
