Hi everyone, i got my car on the road and have been getting to do some good road tests. I fixed the fried ignition system that occured when my coil came loose and shorted out against my carb linkage. Replaced all the wires in that circuit and also the ignition switch itself which was the main problem. Anyways, now that the car is on the road, i have realized that my blinkers dont work.
If i pull the hazard switch, all the lights flash like they should i assume, but if i push the hazard switch all the way in, the two arrows on the dash flash and using the turn signal just stops the side i turn it to from flashing. To get this wierd flashing to stop i have to put the flasher switch in the middle positon, but then the blinkers dont work. My questions are, is the blinker relay bad, does the hazard and blinker share the same relay? Could my hazard switch be bad? Anyone see this problem before? Thanks
