QUOTE(Vacca Rabite @ Jul 29 2010, 06:38 AM)
What is your deck height and compression ratio.
I think I remember a conversation about the AA pistons sometimes slapping the valves slightly when everything is cold and you have tight deck height. But i can not remember the specifics, and could have the facts totally wrong.
That said, why didn't you upgrade your valve train when you put in the 494 cam? Are you using stock pushrods, or the steel cut to fit ones? If stock, you are going to have very poor valve geometry.
Zach
Now I am starting to wonder, but at the time, i think my logic was, if i get 20000 miles out of the motor, that will be about 7 years of driving. Plus, I did not think it was all that far off when I assembled everything. I am getting within 5% of the cams specified lift, and the stem to adjuster angle was not that far out of whack.
