rick 918-S
Apr 10 2004, 03:19 PM
I've looked high and low. I must have borrowed out both my manuals to a friend of mine. He has since moved away and I think lost them in the move.
So. I need a complete wire diagram for a 1972 914. I'm attempting to mate the engine harness from my 928 to the 914 relay board connection. I have the 928 manual on CD so I've got the engine side covered.
Anyone know of an online source?
jonwatts
Apr 10 2004, 03:29 PM
Sent you a PM
rick 918-S
Apr 10 2004, 04:27 PM
Thanks.
Dave_Darling
Apr 11 2004, 11:23 AM
Haynes has B&W diagrams, and Pelican has color ones. I think we've got 71 and 73, not specifically 72... But Haynes does.
There are, of course, also other color diagrams available from somewhere or another....
--DD
rick 918-S
Apr 11 2004, 06:43 PM
Jeff or someone that sees wiring diagrams floating around in their head when they sleep. My car is a 1972. For some reason I have a 1971 harness. I discovered I have a green/black wire. It passes through the relay board. The diagram shows it comes from # 86 Sportomatic (optional) one direction the wire travels from #86 to pin #6 on the relay board. #6 passes through the relay board to the out connector pin #3. Wire goes to an oil temp inducator.
My question is; What the heck is Sportomatic (optional)?
Where does the wire come from really?
I would like to us this wire for something else. What is it connected to under the dash?
Where do I begin to look for this wire on the dash end.
Dave_Darling
Apr 11 2004, 07:54 PM
Sportomatic is the auto-manual transmission. Installed in 25 914-6es, and no production 914-4s. Though supposedly one or two prototypes.
Green/black is likely the oil temp sender wire. I believe that some/many/most 72s actually had that, though very few if any had an oil temp gauge. It is probably not connected to anything under the dash.
--DD
rick 918-S
Apr 11 2004, 08:42 PM
That's what I thought. I'm sick of looking at wiring for a while!
JeffBowlsby
Apr 12 2004, 07:12 AM
What Dave said.
