motomadness1947
Jul 29 2010, 02:19 PM
This answer is important to me as I am a 914 newbie, so please be nice. As soon as I turn the ignition on i hear a relay clicking. I know in the book that you should hear the Fuel Injectors Click when you turn the key on, but this sound like it comes from the relay panel under the dash. What is it or do I have a problem?
My vehicle ( I use the term loosely ) is a 1974 2.0 FI
motomadness1947
Jul 29 2010, 07:13 PM
help, I hope someone reads and posts a reply for me
detoxcowboy
Jul 29 2010, 07:37 PM
one click? I would not worry about it,Conatant clicking?, you should hear the fuel pump, you won't hear the injectors unless your in the engine compartment..
swl
Jul 29 2010, 08:57 PM
The relays for the fuel pump are behind your let ear. Back in the engine bay. You should hear it click, fuel pump activates, 1.5 seconds later fuel pump shuts down.
There are other relays under the dash but they shouldn't click on key on. Is the car doing anything odd (other than clicking)?
VaccaRabite
Jul 29 2010, 09:17 PM
does your car have FI or carbs?
Many carbed cars have a loud fuel pump wired to run whenever the ignition is on. If your car is carbed, that may be what you are hearing.
Zach
motomadness1947
Jul 30 2010, 05:17 AM
It is under the dash and it is a constant click like a turn signal indicator (which it is not) today I will pul the panel and check which one is doing it.
Thanks now that I know it is not a normal click, it is time to dash dive
Bruce
motomadness1947
Jul 30 2010, 09:59 AM
Okay, George Husseys book says that if you hear a constant clicking it is your turn signal, master cylinder warning switch, hand brake warning switch relay being acivated because the warning switch has to be reset of the brakes rebled. so have checked the hand brake warning switch it is acting properly as it only brings the light on when I engage it. I have the wire to the master cylinder warning switch disconnected as it activates the warning light when I plug it in as it is faulty.
So why is this relay still clicking all the time? If I had a ground in one of the brake warning wires, the dash warning light would flash, which it is not doing. The turn signals and hazards are working properly.
Any help for me?
matthepcat
Jul 30 2010, 10:27 AM
I have the same problem with constant clicking sound with the ignition on from the blinker. It has been low on the priority list of repairs so far.
I hope someone out there has some suggestions.
turboman808
Jul 30 2010, 12:01 PM
I have the same thing and it's always been like that. I have a very loud motor so it's drowned out and I just ignore it.
Tom
Jul 30 2010, 12:23 PM
I would try rebleeding the brakes and plugging the wire back on the master cylinder. It is a safety warning. If it is still clicking after you get this fixed where the wire is hooked up and no light blinking, then look for proper ground at the handbrake switch. I had this problem with mine and the ground was iffy at the handbrake switch. Cleaned it up and now all is good.
Tom
motomadness1947
Jul 30 2010, 01:52 PM
So I got into some stuff and then decided I had enough of garage and decided to take her down the road. Guess what. The clicking stops when the engine starts. It is definitely from the blinkers etc relay. God i love these little cars. Masochist to the end
Motomadness1947
detoxcowboy
Jul 31 2010, 09:02 AM
some 914's have a flashing brake failure warning that is connected to the parking brake lamp along with the warning lamp wire from the MC that you disconnected, and the hand brake alert lamp wire that you did not disconnect.. so here is what I think is your fix..
on the back of the brake warning lamp there should be a flashing warning wire still connected
it is a black wire with a green stripe and a white stripe (one of a kind dual stipred wire) connected at the rear of the parking lamp..
disconnect it and protect wrap it.. done..
charliew
Jul 31 2010, 11:36 AM
Or you could go for a little ride and let George listen to it and tell you what it is. Oh shoot I was thinking you were in Georgia.
