QUOTE(motomadness1947 @ Aug 1 2010, 12:34 PM)
I recently purchased a 191-905-855 lock cylinder for my 74 914 2.0 my problem is I can't figure out how to get the old one out of the cylinder housing that mounts on my steering col. I have removed the housing from the column unpluged the plastic ignition switch but can' figure out how to remove the tumbler cylinder. Can any one help me out.
[/b]Problem solved: There is a small plunger hole just in front of the steering lock on the cylinder housing that must be depressed (like me most of the time) to remove the lock portion of the ignition switch. It does not look like anything, but if you put a small pointy object in that hole and pull out on the lock unit. Walla. Once I read though three manuals and lots of google information that is the answer short and sweet.
