QUOTE(KaptKaos @ Apr 11 2004, 09:56 AM)
It is my understanding that there is a right way and a wrong way to drop the front end.
Aslo, is there any adjustment to the steering rack?
it's just a matter of extent. the wrong way is to lower the car down to the bumpstops and change nothing else. the right way is: don't do that :-) ...
if you have less suspension travel, you should increase the spring rate to compensate; few people with street cars do this, however...
it's easy enough to add a 'bump steer kit' that's basically some thick washers and longer bolts. these space the steering rack back up - they're about 12mm thick which is about all the room you have before the rack hits the tub. raising the rack also changes the steering shaft angularity a bit, which can usually be adequately compensated by just loosening the u-joints on the splined center shaft and collapsing it a bit on the splines. a kit like this is about $15, and is nothing you couldn't duplicate with good quality flat washers and appropriate longer bolts from the hardware store, but most of us spring for the kits As Long As we're shopping for other stuff...
you can get as fancy as you like with bump steer kits, raising the attachment points on the steering arm in precise increments. these kits are more, and might be useful for track cars with much more precise requirements. i'd suggest trying the $15 kit and seeing if that's enough for you. you WILL need to reset the toe after raising the rack...
there is no adjustment to the steering rack other than raising its location.
