74 2.0 stock
Listening to the valves after you adjust them, should you be able to hear any unitl they have warmed up? I have about a dozen adjustments only under my belt, alot of them were on my first 2 adjustments just trying to get a feel for it.
Currently I adjusted my valves and can hear maybe 1 or so I guess queitly for about approx. 5 minutes then they are all silent and of course warmed up.. Is that tolerable or normal after an adjustment?
Since they are cold adjusted I can while under the car tap them the .008 or .006 accordingly so am wondering if that tolerance is what I am hearing until theyh warm up? or should I snug them up a bit more??
Basically I do not know how to listen.. How do you listen for good adjustment?
