Okay, this is going to sound ridiculous but... I've got two small condenser coils (Audi) that are going to be mounted in each rear fender well (they're flared, lots of room), ducted up and around the rear tires from X-1/9 side scoops mounted in the rocker panels, there's also two (one on each side) 250 cfm waterproof bilge blowers (4" thermistor controlled) to suck air across the coils when I'm sitting still (rush hour)....Okay, stop laughing
I'm pretty handy with composites, so the ducting won't be much of a problem, in fact the lower half of the duct (removable) will double as the rear wheel well liners. The part I'm still working on is mounting the evaporator in the engine compartment (high and on the firewall) and blowing the conditioned air through the existing heat ducts (return-air low on the firewall). I've got a bunch of aluminized fiberglass from a guy on ebay (the unofficial materials supplier of this project
) that's highly heat reflective and should make for a super quiet/cool passenger compartment when completed......Now that you know my evil plan, you must die
LOL!!
