QUOTE(Vacca Rabite @ Aug 5 2010, 09:12 AM)
Ha!
I actually removed the dealer installed AC from my car.
Zach
Well Zach, I was originally going to say "that my friend is the downside to a vintage non-AC sportscar!" - but now you admit to removing the one dealer option which actually made good sense for our 914s in hot climates or hot months!!!!
You did it to yourself Pal!
Hey seriously - if you're stuck on a "no A/C 914," then do as others suggest & keep your top on in daytime - including overcast days due to infrared & UV still getting through, off in the early am & nights, windows down with the footwell & windshield settings getting fresh air fan at full blast, roll your pant legs up & suck on a bottle of ice water, cold soda or something! I worked for me - sorta!
Otherwise, do what Betty says Clay did, & reinstall your A/C with updated compressor & R134 freon, then chill out with everything closed up!
IMHO it's possible to keep the vintage look of the condenser shroud in the front trunk (DPD or VPC per what was on your 914 from the dealer), & the original under dash vents & controls per original set-up, but with the newer R134 guts such as sold by AA.
Unfortunately, my 73 2L didn't come so equipped from the dealer, so I won't add A/C after-the-fact to mine, but would do the update like Betty's if it had! I spent too many hot SoCal days sweltering in my 914 when it was my DD & only car, on the way to/from meetings with the coat & tie on the pass. seat, pant legs rolled up, running the "Sears 2/75 A/C", sucking on a cold soda, back soaking wet & wishing I had friggin' A/C!!!!
... & we didn't have the PA summer humidity either!
Jeeesh! .... removes the A/C then whines about too hot, I mean really! REALLY! ... mutter, mutter, mutter, grumble, harumph! .......
