I was wondering are the 911 and 914 Torsion bars the same?? Can the 911 torsion bars from 66-89 be interchangeable for a 914-4
chunger
Apr 12 2004, 04:49 PM
I believe the splines are different. If you use the 911 torsion bars, you have to use the 911 A-arms as well.
brant
Apr 12 2004, 04:53 PM
Yes the spline count is different..
plus the spring rate is different too... The usual # thrown around is technically rounded up but the 911 is commonly known as a 19mm bar which is more than the 914...
b
ArtechnikA
Apr 12 2004, 05:23 PM
QUOTE(brant @ Apr 12 2004, 02:53 PM)
Yes the spline count is different.. plus the spring rate is different too...
actually, 914/4 and 914/6 used the same sizes, 17,9mm. the splines are different.
Joe Bob
Apr 12 2004, 05:28 PM
Yup...diff...UNLESS you swap in a 911 front end...then you can use 911 t-bars...
brant
Apr 12 2004, 05:36 PM
wow rich...
I never knew the -6 also had the 18mm bars... I always assumed they had the 19's too..
b
ArtechnikA
Apr 12 2004, 05:39 PM
QUOTE(brant @ Apr 12 2004, 03:36 PM)
surprised the sh!t outta me too the first time i heard it, but the parts manuals confirm. actually, i have an original A-Arm and T-bar downstairs. yup...
