QUOTE(bugsy0 @ Aug 12 2010, 01:19 PM)
QUOTE(tradisrad @ Aug 12 2010, 01:28 PM)
Moral: Add more wires than you think you're going to need.
Good point. In fact I'm considering an external oil cooler but would rather avoid it. Outside temps in MT rarely exceed 90F and are almost always below 80F. Motor is a Raby 2270. I might run an extra wire just in case.
drill a hole, and sleave a bunch of wires (you may want to add stuff in future, extra temp gages, fans, etc.... use a sleeve , tape teh wires togtehr and sleeve them outside of car, tehn run teh hole sleeved bundle at once thru the tunnel, use grommetns on teh holes it passes thru.
90F ambient is not too cold to prevent too hot oil, so use care, make sure you have a calibrated oil temp gage.
