Hi All,
Trying to get the car back to life, has been 5 years parked in the garage. Dropped engine cleaned everything and put engine back in. Now I can't get it running. I find that the injectors do not fire when cranking. Upon trouble shooting one thread suggested with points closed turn key to run position and use a non-metallic probe to open the points, this should fire the injectors. No luck. I do have 12v measured at the resistor pack to each injector, double relay is picked and grounds are all in place and ecu case grounded as well. I removed the injection loom today and metered all the connections from ecu to all points, all connections have 0 ohms continuity. I was wondering if there was a couple more places for me to check and work towards??
