patssle
Aug 13 2010, 03:13 PM
Is there any major advantage over a 2 out vs 1 out exhaust for 914-6? Power or sound? Any reason to pick one over another?
pcar916
Aug 13 2010, 03:39 PM
The sound is, IMHO, better out of a 2 in 2 out can. It also depends on whether or not your engine is big enough to produce too much back-pressure.
My 2.7L E spec motor worked great with a 2-in/2-out was too much for the 2-in / 1-out. My 3.6 won't work with either one.
I thought about making a 2-in / 2-out with my own internal porting, but it was easier to use other solutions, like SuperTrapp or phase-9's...
But then I don't mind the noise.
DanT
Aug 13 2010, 03:40 PM
twin pipe..........beautiful sound.
twin pipe if properly executed..........better power.
twin pipe.........looks great
had a nice twin pipe on my 2.7RS 914-6 and loved every minute of it.
now I have my '75 2.0L twin piped
whatabout1
Aug 13 2010, 03:53 PM
Some twin out's can have a resonance at the mid range. Loud.
Dan, what are you running ? M&K GT3 ?
DanT
Aug 13 2010, 04:01 PM
that is a custom made twin pipe on a stock 2.0L banana. 4 cylinder
kind of rare
the one I had on my 6 was a partially gutted stock muffler with correctly placed twin pipes...there are several places to make the twin pipes exit. Some make it quieter, some make it louder, some give it a bit more torque...especially if the pipes are the correct length.
patssle
Aug 13 2010, 04:09 PM
QUOTE(pcar916 @ Aug 13 2010, 01:39 PM)
2.7L too much for the 1 out...why? My 3.0L on the 911 has 1 out...and I was planning on putting it on the 914 for the conversion.
BigD9146gt
Aug 13 2010, 04:31 PM
I don't have the equation, but you can calculate the proper exhaust size, both headers and muffler. I went with what was recommended by several people different sources that know what they were talking about, 1 5/8" headers. However, I was sold on the sound of the Dansk sport 2in2out from my boss' car.
jt914-6
Aug 13 2010, 04:45 PM
I'm using one in/one out X2.....although a crossover tube might help....3.0 six
Ericv1
Aug 13 2010, 04:58 PM
I just installed a Triad 2 in/ 2 out and it sounds awesome. Mine displacement was on the small side so it was recommended to go with
1 1/2 inch headers.
Steve
Aug 14 2010, 10:15 PM
I have a stock Euro 3.2 and i tried the two in two out sport muffler and it was way to loud for my neighborhood. It sounded like someone was bouncing metal balls off of the neighbors garage across the street. I took my car for a spin and noticed better top end power, but took it off anyway and put the single exit Bursch turbo muffler back on. Much quieter. Sport muffler went back on ebay the next day. Since then I have heard of silencer inserts for the sport muffler that are removeable for track events. That might have been the way to go.
Justinp71
Aug 15 2010, 12:42 AM
I have the M&K 2in 2 out, It sounds great. But it resonates on the freeway and now most of the time I have the pass side capped and un cap it for events. Plus its more ...
with one capped.
IronHillRestorations
Aug 15 2010, 09:01 AM
You probably get more top end power with the two outlet, but 90% of them I've heard have annoying resonance in the cabin. A few of them would just wear you out as the worst resonance came at cruising RPM's.
For anything up to and including a STOCK 3.0 the stock Porsche banana muffler is hard to beat. You might loose a little on the top end, but a little bit of restriction helps the low end torque.
Bigger and more open exhaust isn't always the best thing for the flat 6 engines, a little back pressure isn't a bad thing.
patssle
Aug 15 2010, 10:08 AM
Great, thanks guys! Looks like the stock muffler from the 911 will be the way to go.
