Richard
The problem is in the actual transmission as you cannot move it out of 4th even getting under the car and shifting by hand on the side shift comb.
But I think i got it this time.
Well I had an extra 4 hours today so I pulled out the transmission stack and realligned it. I mocked up the shifter comb and I could finaly see what was wrong the 4/5 shift slider was to far twards the transmission wall and the comb would catch going into 4th then slip past the notch into no mans land the comb would then try to shift into neutral and 2nd at the same time but due to already being in 4 it was locked in place in 4th.
So i realligned the 4/5 selector mor twards the gear stack using my mock up with the shifter fork and put the gear stack back into the transmission. I first assembled the rear of the transmission with 4 bolts to make sure shifting in and out of all gears by hand was possible. that was a success then buttoned up everything and I am now driving again
All gears are smooth and shifting in and out of all gears.
Started at 10:30 finished at 1:10 not to shabby.
drove about 20 miles and shifed in and out of 4th many times seems to be good we will see.
