QUOTE(ruddyboys @ Apr 13 2004, 06:54 AM)
Looking at it more closely, there are three springs, the center of the fatter spring is a flat spring. I allready replaced this spring with a regular T4 spring. I really dont want to have to pull all the others and remove the head from the other side and replce them, getting those locking pieces on are a pain in the ass. Will I have any problems with one T4 spring and these other T1. If so were would you get a replacement 3 piece spring?
Miss-matching springs is
not a good plan.
Gene Berg, 1-714-998-7500, part # GB 269-1 for a single triple spring.
You should check these springs almost weekly...like I said these are racing springs. 180lbs at 1.5" and around 320-340lbs at 1"
The other springs are most likely pooched, I would replace them all with dual springs. They are around 125lbs at 1.5" and 225lbs at 1"
If one spring has gone flat what are the others like? "I" would have the other springs checked for poundage.
What is the advantages/disadvantages of:
Dual Spring setup
Heavy duty single spring setup
When do you even need to go to an alternate of the stock springs.
L. McChesney
Valve float at high RPM's and dropped seats...this is a heated debate and there are two camps of thought on this one.
One side says more spring =less float is better for the seats. More spring does take more hp to run them.
The other side is less total valve train weight, less spring frees up hp.
I've been checking into this as I've used the dual on the T1's for years with great success. On the 2.0 heads with the T1 dual there will not be much meat left on the exhaust guide boss, once you cut for the duals. On the T1's use the duals on any hipo cam always.
In T1 land the rule of thumb is HD singles for up to 6000rpm, 7500 for duals and above that it's triple or chevy style springs.
If you are doing a hipo T4 I would use the HD T4 spring at least.
