Does anyone have a method for the alingment of Doors? The only adjusments identified is with the front hinges and the door latch on the rear door encasement.
Also, what adjustment techniques can you use to align the windows with the door seals? I have found the adjusting screw on the front underside of the door that seems to adjust the fore and aft rake of the window channel, and how far the window channel leans in. I have also found the adjusting slot screw forward of the channel adjusting screw, which seems to be a stop for how high the window will crank up. Are there other? What do you align first?
Thanks,
L. McChesney
