QUOTE(realred914 @ Aug 17 2010, 03:13 PM)
that 1970 1.7 FI engine is pretty peppy, the car is also lighter than teh late cars, a good combo, (plus the early higer power 1.7's motors got great mpg actually!) I have had one, and they are great, seem to have a bit quicker power curve to me than my 2.0 liter car.
you may well stick with that FI system rather than carbs. and enjoy the better drivability, MPG, and less maintanence of the stock FI, the early motors, the first 1.7's were very nice. if it aint worn out, then have fun with it.
then save up for a much better motor latter, the upgrade you want to do has too many negitives for me for the small carb and limited performance upgrade (if not done just right, you can down grade the power with a switch , make sure you have the right parts). now however if youre intent is a monster power motor , then do it right and get some big arsed carbs on there, supper cam, big bore, special heads, headers etc..........make it REALLY worth the trade offs of switching to carbs.
for best parts, for the case, early cases have less heat damage than smog contraol cases genrally. get a case that is inspected, thats the main thing, check for cracks, and bore , some things can be repaired, , others you toss the case. (ie... bore shot)
for heads, well make a matched set for first, look them over if you can make a set that are not cracked, that is a bonus, for supper reliability, new sets are a nice thing to have put in, if your going to the time of regrinding the seats, might as well replace them is my opinion seeing as the only way I figure to tell if visuially fine seats is getting looose or not is to remove it and see how much force it took!!!!!
so see what you got first, then depends on budget.
contact Pierce manifolds Inc. 408 842-6673 (Gilroy Calif. ) they are a leading Weber distributor and experts in all Webers, they have all the goodies, and pumps / regulators and have some very good books on tuning and carb jet selections for variuos engines. really good folks, there, and very knowledgeabnle, they will help you out, there advice is great, even if you dont buy anything, very helpfull.
I have been hearing a lot about keeping the FI but in my case it is trashed. it was a mess on the top of the motor mice chewed frayed the control box was rusted and a wiring mess. the webers came with it and I thought I could use them.
