I've seen mention of this whispered around, but I have a timing issue.
When I set the timing after reconditioning the distributor in my 1971 1.7 orange love sunburst explosion 914, I added a Pertronix unit and went on my merry way. I notice that at constant high speed or hard acceleration after 3000rpm that it hesitates (or misses). It took me a long time to think that it might be a timing issue, so I pulled out the timing light to re-check it. In the meantime I've dealt with other issues like vacuum leaks, a bad MPS, etc. so this timing problem was underneath all of the other problems.
With a lead-footed friend in the driver seat, he tried to maintain a constant 3500rpm while I shoved my face over the inspection hole with the timing light. It isn't quite getting the mark to line up, so I'm a little advanced still.
The issue? I can't physically rotate the distributor any further because the vacuum advance is already pushed up against the fan housing. Awesome!
Um, what? Please tell me this isn't a "your engine was rebuilt wrong somewhere along the way, so go rebuild it right" issue.
In a blazing moment of ghetto mental imbalance, I pulled the spark plug wires from the distributor, and moved them all over one notch. That does not work. So I put them back. When I installed the distributor I made sure the rotor was pointing at cylinder #1 at TDC.
I'm confused.
