QUOTE(iamchappy @ Aug 20 2010, 08:07 PM)
I cant see any reason why a pertronix type of sensor couldn't replace them...
Do the FI have dual contacts, been awhile since i had a look at one.....
Yes - two contacts 180ยบ apart. Each contact fires a pair of cylinders, only half of them when the intake valve is open (i.e. - timing isn't that critical...) I do not recall if they fire on the contact make or break. But there's not a lot of room. Does the Pertronix use an eddy-current sensor on the existing points cam, or does it require a separate magnet wheel?
I almost think it'd be better to use an inductance probe over a pair of spark plug wires. I have no doubt the trigger points are cheaper than that, which if you're VW/Bosch is a big deal with million-unit production volumes...
