So, for the past two weeks I've been trying to sort out the carbs. Since most Carb issues are actually engine/ignition related, I've spent some time working on the basics to ensure I can tune the carbs. To this point, I've:
1. Adjusted the timing (30 degrees BTDC)
2. Adjusted the Dwell (38 degrees)
3. New cap, rotor, points, wires, and plugs gapped at .60mm.
4. Adjusted the valves (Although, I may try this again as I've just discovered the backside methon on Pelican).
5. Ensured that I have no vacuum leaks at the manifold or the carb bases.
6. The throttle shafts feel very tight.
7. The floats are adjusted with the PMO float gauge and they are in between the two upper lines which is 33-35mm.
Here's the first issue. Barrel number three only pulls 3 bars while all other barrels pull 6 bars. I've tried to adjust it out but that's as high as it will go. I've cleaned the idle and main jets as well as the air correction and emulsion tube. Any suggestions on where the blockage is?
The second issue manifests itself at around 3200 rpms and above. I get a considerable amount of popping through the exhaust. This only occurs at cruising speed where the butterflies are barley open. If I give it some gas or go WOT, the engine pulls very strong and the popping is gone. Under 3200 rpm's, there is no popping. From what I've read, this is a rich condition. But, where do I start making the changes, in the main jets?
Finally, I just drove it a 100 mile round trip and here's the condition of the plugs. I don't know what to make of it. Is it too lean? I'm not an expert and would greatly appreciate some help to diagnose these issues.
I know someone would ask so here's how the carbs are setup.
Idle Jet=55
Main Jet=130
Venturis=32
Air Correction Jet=185
Emulsion Tube=F3
1969 2.0L "E" engine code with the following
Solex Cams
"S" pistons and cylinders
Weber 40 IDS triple throat carbs.
Everything appears to have been setup to "S" specs on the carbs except the air correction jets. From the Haynes Weber manual, they originally were 180's instead of 185. Any help would be appreciated. Thank you.
