Looking for that hard to find oil pressure relief valve for your 914-6/GT conversion or RSR tribute? Look no further. This is the very best replica valve we've found.
This is a modern alternative of the factory Oil Pressure Relief Valve (Porsche pn #901.107.285.20) The "Uberdruckventil". This model uses the cap itself to set the pressure. Simply screw the cap to the desired pressure setting and you're good to go (comes pre-set at 75lbs.) The cap is hand machined to match the original valve in appearance. It has the correct 26x1.5 threads and is dimensionally as close as can be. This unit is made from a commercially produced valve , which helps keep the cost lower (there is an RSR copy that also looks correct, but is non adjustable and €900.00 euro’s!!)
There is a very limited number of these valves available at this price.
$595.00 plus shipping.
