chrispy
Aug 23 2010, 08:34 PM
i am in the process of reassembling my 1973 914 doors.
the window fuzz is badddd . are there any after market fuzzies out there and how do i attach them....aa price is to high for my budget
thanks chrispy
jeeperjohn56
Aug 23 2010, 08:46 PM
Hey Chrispy, I got my new fuzzy replacements from AA-(auto atlanta), They were $38.50ea, not cheap but they have them, you trim to size hope that helps. John
dr914@autoatlanta.com
Aug 24 2010, 08:41 AM
QUOTE(jeeperjohn56 @ Aug 23 2010, 07:46 PM)
better than the 57 buck factory ones....AND they are just the same except for the screw holes missing!
tomeric914
Aug 24 2010, 09:17 AM
Chrispy,
You'll waste more time (which is money) trying to figure out how to get by on the cheap. Do it half-assed and you'll be doing it again real soon.
The AA ones fit perfectly and are worth the money.
andys
Aug 24 2010, 09:27 AM
Can you set me straight; there's a window track at the rear of the door, and one at the front. Does this AA fuzz replace both of them?
Thanks,
Andy
jeeperjohn56
Aug 24 2010, 11:59 AM
Andy, The fuzzy strips that are from AA are only the one's for the aluminum strip between door glass and outer edge of door skin. John
chrispy
Aug 24 2010, 12:21 PM
all right, all right ! i'ii quit being cheap and order aa fuzzys
thanks for the feed back, chrispy
tomeric914
Aug 24 2010, 12:56 PM
You'll need to remove the outer aluminum strip from each door to replace the fuzzy strip properly. There are 3 screws typically rusted in place. Get those out and then CAREFULLY push the aluminum strip down to remove it. If you're not careful, you WILL bend the aluminum piece.
After its off, get all of the fuzzy strip out of its track and clean it up real nice.
Then look at this thread:
http://www.914world.com/bbs2/index.php?showtopic=109244
andys
Aug 24 2010, 01:47 PM
QUOTE(jeeperjohn56 @ Aug 24 2010, 10:59 AM)
Got it, thanks. Now how about the fuzzy for the rear track?
Andys
