Hello all. Thought I would share with the group the final results of my weeks of research, machining, drill tapping, thread cutting and assembly of my home made fuel rail. Unfortunately I didn't take pic's of the various steps but only the finished product. The rail are aircraft quality extrusion blanks. I decided to use brass fittings in my first attempt because it is less expensive than race fittings such as Russell performance
I didn't know how the fuel rails would perform so I used a great deal of caution at all steps of the process and mostly at engine start up. The only leak I experienced was at the exit end of the driver side rail due to (of all things) a mismached end fitting, the theads didn't seat propperly. BTW, I don't know if you can make it out in the pic's but the rails are bracket mounted to the injector hold down bolt and stud.
I now have over five hundred miles and days of 100 deg's on them plus some very hard driving, so I feel comfortable that they will continue to perform well.
