put together engine, install engine and transmission, install main wiring harness (removed it completely for some unknown reason and didn't mark a single wire), change out fuel lines, install tank, install new brake lines, install dash (completly removed) or at least mount the gauges somehow, put doors back on, install windshield....etc...etc...
You help me and I will help you!
The only reason I have not regestered is I don't think I can have mine back together in time!
I only need to clean and paint the engine bay, clean the engine, install the alternator, oil return tubes, heat exchangers, muffler. Reinstall the motor, assemble the trailing arms and reinstall them! Bleed the brakes replace the oil pressure sender, align and test drive!!
I am feeling your pain!!
Jeff
