QUOTE(Silver72 @ Aug 27 2010, 01:01 PM)
My headlights are non-sealed units. They have a main bulb in the middle with a smaller bulb near the bottom of the unit. I am looking for close to factory replacements of the lense....and inprove lighting at night. Any suggestions?
the general purpose halogen "sealed beam" bulbs are a direct fit to the standard 914 sealed beam system./ these are sold at most autoparts stores, and are a HUGE improvement over the standard sealed beams of past.
these are real halogen gas bulbs mounted inside a sealed beam globe and refetor, so very close to factory looks in general appearance to the old sealed beams. this is a far less expensive alternative to the other older method of adopting the better halogen bulbs, which was with removable bulbs in H4 housings. The H4 conversion was somewhat pricey, compaired to teh sealed beam style halgens now available.
give that a go. heck i me and tradisrad pick up several nice pairs of sealed beam halgens at pick your part auto wreckers
some time ago, for a couple bucks each or so. look in the wrecked american truck section
. seams many old trucks there have round headlights, the trucks were some of the hold outs in styling i guess, utilitarian to teh core.
so give the halogen round "sealed beam" lamps a try, so long as you keep the same wattage, you system will be ok fuse wise,
however since the car is old make sure you have fulll voltage tot eh bulbs, if not, start cleaning ground points, then hot points, all conectors fuse ect. some times the switch wears and becomes a huge votlage drop (they will get warm or even hot
) relays may help you out, and are needed for higher than stock wattages.
however i think you will be plesantly surprised how nice the new fangled halagen round sealed beams are.
and they are a direct fit, and look "right" to all but councurs showing. cost is a no brainer on these,
only thing cheaper is old style sealed beams, then your back to 1930's technolgy
hey good luck in lights remeber the stuff in bold above is first and formost to bright lights.
happy moteoring!!!! vroomvroomvroom 914914914914914914914
