Mine do too. Sort of. I think the piece your finger is on is attached with rubber studs that can be tweeked. Try a soft rubber mallet. Maybe not.
jeffdon
Aug 27 2010, 03:23 PM
QUOTE(windforfun @ Aug 27 2010, 02:20 PM)
The rubber nubs tend to keep wanting to center in one place. Grrrrrr.
windforfun
Aug 27 2010, 03:27 PM
I'll check later when I get home.
john rogers
Aug 27 2010, 04:37 PM
If I remember correctly there are 3 allen head screws on the inside mount that allow the headlight to be moved around if they are loosened and then the light cover can be adjusted. I would say to NOT bang on things as the pivot is some sort of POS cast metal that VW had left over from WW2 and they break off easily so use caution.
Aug 27 2010, 04:39 PM
QUOTE(jeffdon @ Aug 27 2010, 02:16 PM)
How do I align the headlamp doors?
By reading the Tech Article on how to adjust your headlights ...
THANKS! As an aside, I just took the car on its first run on skyline blvd (andy will know this road), and man, I forgot what a go-kart these things can be.
Jeffs9146
Aug 27 2010, 04:58 PM
I would adjust the front body piece in front of the light before adjusting that light!
It has a couple of alen screws also so you just loosen them, adjust its possition and tighten them again!
Aug 27 2010, 05:06 PM
QUOTE(Jeffs9146 @ Aug 27 2010, 03:58 PM)
No screws, just rubber plugs ...
windforfun
Aug 27 2010, 05:30 PM
QUOTE(jeffdon @ Aug 27 2010, 03:52 PM)
QUOTE(SirAndy @ Aug 27 2010, 03:39 PM)
Keep it out of the trees.
jeffdon
Aug 28 2010, 08:18 AM
This procedure seems only to alter where the cover stops in the vertical plane. I need to adjust in horizontal. Back and forth, or in my case, just back a bit.
windforfun
Aug 28 2010, 09:36 AM
QUOTE(john rogers @ Aug 27 2010, 03:37 PM)
Looks like this is the case assuming the through holes in the sheet metal are large enough.
Aug 28 2010, 02:16 PM
QUOTE(jeffdon @ Aug 28 2010, 07:18 AM)
It's in there. You need to read the text between the images ...
Andy
