Well tonight after about a month and a few looked at rust buckets I final found a 1973 914 in Deltona FL.
Owner was super nice and brought the car up to me,about 600 miles one way. He got there when he said and the car was as described.
The car is a 1973 2.0L with dual webbers. Paper work stated it had the euro pistons and a cam to match the webbers. MSD 6A box with matching coil and dizzy. 15" Fuchs alloys with a 911 Bilsten front and 5 lugs also out back. Pretty low profile tires.
Car started great and we backed it off the trailer. I did a little parking lot test drive and off I went. First thing I notice,as a first time 914 driver, first gear is really tough. It only really worked well with a fair amount of RPM's. If not she felt dead. I guess the linkage might need a check on the webbers as the pedal was pretty hard to feather. Next thing I notice is how tight the shift pattern is. I touched reverse a time of two on down and up shifts.
So I hit the highway and cruised @ 70 mph with the tach pushing 3400 RPM. I was worried that I had not found 5th. But after feeling I had power and the car seemed to sing I went with what it wanted. I didn't know till I searched a few mintues ago that is a common cruise RPM.
Car rode and drove great...other than the touchy first gear that I am still learning.
Half the gauges where out...I had speed,tach,fuel and volt. The car has the center console.
So after the hour ride home I was happy with the car.
SO any shifting tips for a 914 newbie??
Any idea of the horsepower this car would have??
Ok last one....anything I need to add the keep the car running safe,heat and oil pressure/temp wise?? I hear heat kills these cars
I plan on repainting the rocker cover and targa in short order and a full respary/bodywork in the spring
