QUOTE(jaxdream @ Aug 31 2010, 07:00 AM)
This has been greatly informative , as I had no idea that there was a different Brad Penn oil. This particular info narrows it down to the very EXACT information that most people need ( not very informed ) such as I , now with the correct information , if I choose to vary from it , I only have myself to blame for my engine failures. Having used the castrol GTX 50 weight in my past air-cooled vehicles ( motorcycles, VW bugs ) that was supposed to be the stuff , since coming to these forums concerning air - cooled engines , I have read about using the Brad Penn oil religiously , but no one ever said exactly which Brad Penn to use , only saying use Brad Penn oil.
Damn , this is good ------- a very big Thank You to Jake Raby !!!!!!!
Jack / Jaxdream
The "other" Brad Penn has been around for a while but it is not well known enough to be marketed at a level that caused confusion until recently.. Fact is some re-sellers were taking advantage of people not knowing the difference and those people were price hunting, not buying from people who even knew the difference or cared about the difference in the two oils.
I noted this when I had a turn key engine come back for a repair and the oil in it wasn't green.. I chewed the customer out and he maintained that it was Brad Penn oil, he even had the bottle which had the wrong label on it! He didn't know the difference and he was price hunting and that lead to an issue that helped compromise his engine..
We then found two 55 gallon drums of the wrong oil at a shop that uses our engines in replicars, they had been filling the engines with the wrong oil for over 3 months because they were sent the wrong oil!
BTW- The Castrol GTX is a classic example of an oil that went from very good to horribly bad with reformulation. In the late 90s when the whole VW industry started having worn cams and lifters no one knew why, except Castrol...
Formulations can change and NO ONE has to inform the buyers... Those constantly changing variables are what finally drove me to say the hell with it and have our own oil.
