My car hasn't been running in about 6 years. I picked up an engine from a parts car and today was the first time I've heard it run.
I've got the fuel pressure set at 34 psi per my chilton's manual, I installed a petronix electronic ignition and I recently went through my fuel injection wiring harness to make sure all of the ends were in good shape. I've got between 125 and 150 psi on all 4 cylinders. I've got a new set of plugs, wires, cap and rotor. I just put new fuel lines throughout the car and relocated the fuel pump.
It wants to start, but dies almost immediately. I've moved my timing around on either side and it seems to be close based on how hard it tries to start.
I'm not sure what happened but I got it to start once. It idled at around 3500 rpm and it was popping a little. I think the popping may have been because my timing was off and I needed to adjust the timing gear one tooth to give me a little more room for the distributor. Other than that it would respond to throttle input and it sounded pretty good.
I could have an air leak somewhere, but I would think it would still start as long as the air leak wasn't too big. Anyone have any other ideas? My distributor is pretty beat up and I was thinking that possibly my trigger points may be a problem. I've got another distributor to try so I'm going to swap distributors tomorrow.
