QUOTE(obscurity @ Aug 29 2010, 12:07 PM)
Thank you everyone! From the looks of it the center of gravity is about the centerline of the bumpers. Thats a big help!
Exactly. That is the CG. And they are easy to make. They make a great "learning to weld" welding project - so long as you have done some practice first and your welds are sound. You can get the engine stands from Harbor Freight cheaper then you could buy the steel parts to make it.
I bolted mine directly to the 75/76 bumper shocks mounts. Making a mounting plate for early bumpers would not have been hard at all to do.
The cross beam down the middle is critical for stability. It ONLY has the be tall enough for the car to clear the cross beam at the bottom for the full 360 rotation. Higher then that and it starts being difficult to work on.
You can see pretty easily where I used the engine stand, and where I used steel stock. I asked the same questions you are asking now, and looked at the same plans. IN the end, I discovered it was easier to just make it.
I put mine on casters, and there were several times where I rolled it out of the garage for whatever jobs needed to be done. It was very sturdy. And when I did not need it any more I sold it for a small profit.
Zach
