QUOTE(patssle @ Aug 31 2010, 05:35 PM)
Bumpers!
If you are going carbs on both engines you can get away with only one SS fuel line. I think webers like 4.5 psi or something like that. The reason people get 2 is that one line is the feed, and one line is the return for FI cars. IIRC 1970~1974 cars had 9mm feed fuel line, and 8mm return line. I hear that later cars are both 8mm.
IMHO if you are going to the trouble of running one new fuel line, you might as well run the return line too. Because you might change your mind later and go FI.
IMHO you should go with stock replacement sizes,, are you making more than 300 HP? Then maybe you might want a larger feed line.
Please forgive my shameless plug,,,
http://www.914world.com/bbs2/index.php?showtopic=110158-Robert
