QUOTE(76-914 @ Sep 1 2010, 09:50 AM)
Don't spend too much time messing with it. It only takes an hour or so to drop the engine. BTW, next time use a six pt socket and a few long extensions. The ratchet will end up back by the starter but you get a good bite on it.
Good point- i needed longer extensions to get a better grip on it.
Already released the bolts on the exhaust studs, can't get a dremel in there, I have a dremel with the flat vibrating blade set up. will get new blade and if nothing else cut off that pipe with the
