QUOTE(porschenut @ Apr 15 2004, 06:12 AM)
Just did the BMW front upgrade....................
If you get a "long" but firm pedal, you do not have enough fluid capacity in the new system. I would guess that you still have the 17mm master cylinder and you need the 19mm one to supply adequate fluid capacity due to the larger front caliper pistons.
Like most things, this "UPGRADE" isn't. All you have done is "upgraded" the amount of heat the non vented rotor has to dissipate. You have also increased the front piston diameter vs the rear upsetting the brake balance, biasing it further to the front. This is why you can throw the proportioner away, the rears are no longer doing anything except probably increasing your stopping distance.
